‎03-28-2022 08:02 AM
I have a script include which get the group from assignment rules. And then I need to display this group in the record producer form in portal.
The script include works because when I do a gs.info it is showing the group name. but issue I am having is when assigning the returned value to a variable/object it does not seem to store it.
When I do a gs.info on the variable it is saying undefined.
Also in client script not showing group name.
script include function:
getAG: function(){
//var current = this.getParameter('sysparm_current');
gs.debug('HR AG');
var subjectPerson = this.getParameter('sysparm_req_for');
var prodID = this.getParameter('sysparm_prodID');
var contactType = 'self_service';
//var source = '[producer.source]';
var AG = '';
var grHrService = new GlideRecord('sn_hr_core_service');
grHrService.get('producer', prodID);
var currentServiceTable = grHrService.getValue('service_table');
var currentTopicCategory = grHrService.topic_detail.topic_category.getDisplayValue();
var currentTopicDetail = grHrService.topic_detail.getDisplayValue();
var currentHRServiceName = grHrService.getDisplayValue('name');
var grSubjectPerson = new GlideRecord('sys_user');
grSubjectPerson.get(subjectPerson);
var currentLocation = grSubjectPerson.getValue('location');
var grCase = new GlideRecord(currentServiceTable);
grCase.setValue('hr_service', currentHRServiceName);
grCase.setValue('contact_type', contactType);
// grCase.setValue('source', source);
grCase.setValue('subject_person', subjectPerson);
grCase.setValue('location', currentLocation);
var grAssignmentRule = new GlideRecord('sysrule_assignment');
grAssignmentRule.addActiveQuery();
grAssignmentRule.addQuery('table', '=', currentServiceTable);
grAssignmentRule.orderBy('order');
grAssignmentRule.query();
var filter;
var found = false;
while ( grAssignmentRule.next() && found == false ) {
filter = grAssignmentRule.getValue('condition');
if ( filter == '' ) {
continue;
found = GlideFilter.checkRecord(grCase, filter, true);
if ( found ) {
gs.info('HR AG match: ' + grAssignmentRule.getDisplayValue('group'));
gs.log('HR AG match: ' + group);
AG = grAssignmentRule.getDisplayValue('group');
return AG;
if ( found == false) {
gs.info('HR AG: no match');
client script:
var ga = new GlideAjax('sn_hr_core.HRCaseAccessRP');
ga.addParam('sysparm_name', 'getAG');
ga.addParam('sysparm_req_for', g_form.getValue('requested_for'));
ga.addParam('sysparm_prodID', g_form.getUniqueValue());
ga.getXMLAnswer(getResponse);
function getResponse(response){
var answer = JSON.parse(response);
g_form.showFieldMsg('assignment_group',answer,'info');
‎03-29-2022 02:45 AM
you didn't share what came in alert for response?
use this
ga.getXMLAnswer(function(answer){
alert(answer);
Also share gs.info() for this
if ( found ) {
AG = grAssignmentRule.group.name;
gs.info("AG->" + AG);
return AG;
‎03-29-2022 02:39 AM
HI
use this
alert(answer);
if ( found ) {
return AG;
‎03-29-2022 03:10 AM
‎03-29-2022 03:17 AM
means your script include function is wrong and is not returning value
try to debug step by step by adding gs.info() statement
since script include is not returning it's showing as null
