script is not running properly
chandan31
    var identifer = g_form.getValue('current_shift_identifier');
    var wsOptions2 = 'BR';
    var wsOptions1 = 'VR';
    var wsOptions3 = 'SR';
    var wsOptions4 = 'VUF';
    var wsOptions5 = 'VP';
    if ((identifer.startsWith(wsOptions2)) || (identifer.startsWith(wsOptions3)) || (identifer.startsWith(wsOptions1))) {
        g_form.removeOption('indicate_your_start_week', '6');
        g_form.setVisible('indicate_your_start_week', true);
    } else if ((identifer.startsWith(wsOptions4)) || (identifer.startsWith(wsOptions5))) {
        g_form.addOption('indicate_your_start_week', '6','6');
    else
        g_form.setVisible('indicate_your_start_week', false);
Hi All,,
This script is not running in onchange client script , in this script once the  field is disappear after that it is not visible while the current shift identiter field please modify the script .
3 ACCEPTED SOLUTIONS
Harsh_Deep
Hello @chandan31
Please try this
    else {
Mark Correct if this solves your issue and also mark 👍 Helpful if you find my response worthy based on the impact.
Hello @chandan31 ,
Use this -
    if (newValue == '') {
       getVal();
getVal();
function getVal(){
    else {
This will execute onChange and onLoad as well.
Amit Gujarathi
HI @chandan31 ,
I trust you are doing great.
Please refer the below updated code.
    // Check if the form is loading or if the new value is empty, then exit the function
    // Get the value of the 'current_shift_identifier' field
    var identifier = g_form.getValue('current_shift_identifier');
    // Define the identifiers that you want to check against
    var wsOptions = ['BR', 'VR', 'SR', 'VUF', 'VP'];
    // Check if the identifier starts with any of the defined options
    if (wsOptions.some(option => identifier.startsWith(option))) {
        // If identifier starts with 'BR', 'VR', or 'SR'
        if (['BR', 'VR', 'SR'].includes(identifier.substring(0,2))) {
        // If identifier starts with 'VUF' or 'VP'
        else if (['VUF', 'VP'].includes(identifier.substring(0,3))) {
            g_form.addOption('indicate_your_start_week', '6', '6');
        // Make the 'indicate_your_start_week' field visible
    // If identifier doesn’t match any option, hide the 'indicate_your_start_week' field
    else {
Was this answer helpful?
Please consider marking it correct or helpful.
Your feedback helps us improve!
Thank you!
Amit Gujrathi
Hello @chandan31
Please try this.
Amit Gujarathi
HI @chandan31 ,
    else {
Thank you!
Amit Gujrathi
Hello @Amit Gujarathi
I already gave the same answer, then why this again ?
Please don't try to confuse readers.
And we are from one community only so we don't have to change for accept solutions and helpfuls.
We have to chase for helping the persons.
it is working on onchange but onload it is not working because  identifer is populating the loading the form
I have created on load client script also but not working
