Send all work notes history to External system via flow designer
Priyadharashin1
Hi all,
I need to send the work notes history in the below format to external system using flow designer. Also, while Inbound, I need to process the work notes history and store it in Incident table. For inbound I am using Transform Map. Kindly provide some suggestions. Thanks.
"workNotesHistory": [
"workNote": "XXX",
"date": "XXX",
"user": "XXX",
"order": "XXX"
"workNote": "XXX",
"date": "XXX",
"user": "XXX",
"order": "XXX"
Hayo Lubbers
Hi @Priyadharashin1,
Getting all the work_notes out, should be possible via the getJournalEntry function.
var grIncident = new GlideRecord('incident');
if (grIncident.get('407bfe6b97142110b4f672571153afc9')) {
    //gets all journal entries as a string where each entry is delimited by '\n\n'
    var notes = grIncident.work_notes.getJournalEntry(-1);
    //stores each entry into an array of strings
    var na = notes.split("\n\n");
    for (var i = 0; i < na.length; i++)
        gs.info(na[i]);
Would deliver (in a background script):
*** Script: 20-02-2023 19:34:56 - System Administrator (Work notes)
Work Note #3
*** Script: 20-02-2023 19:34:51 - System Administrator (Work notes) Work Note #2
*** Script: 20-02-2023 19:34:45 - System Administrator (Work notes) Work note #1
*** Script:
Based on : https://developer.servicenow.com/dev.do#!/reference/api/tokyo/server_legacy/c_GlideElementAPI#r_Glid...
If you combine that and split it (lazy splitting, since it is an example, you might want to split it in a better way with a proper regex to prevent issues with different date/time formatting etc.), you get something like this:
    var result = [];
    for (var i = na.length; i >= 0 ; i--) {
        var nb = na[i].split("\n");
        if (nb && nb[0]) {
            var yourDate = nb[0].substr(0, 10);
            var yourTime = nb[0].substr(11, 8);
            var yourDateTime = nb[0].substr(0, 19);
            var yourUser = nb[0].substr(22).split('(')[0];
            var yourWorknote = nb[1];
            var worknote = {
                "workNote": yourWorknote,
                "date": yourDateTime,
                "user": yourUser,
                "order": i
            result.push(worknote);
    gs.info(JSON.stringify(result))
resulting in:
[{"workNote":"Work note #1","date":"20-02-2023 19:34:45","user":"System Administrator ","order":2},{"workNote":"Work Note #2","date":"20-02-2023 19:34:51","user":"System Administrator ","order":1},{"workNote":"Work Note #3","date":"20-02-2023 19:34:56","user":"System Administrator ","order":0}]
If the answer helped you in any way, please mark it helpful. If it your solution, please accept it.
Sorry actually Im not using flow here. Im trying to get this from sripted rest API or business rules.
