ServiceNow Metrics relationship between sc_task and metric_instance
Scott29
I created new metric definitions for the sc_task table. I have never created a relationship between tables before. How can I make a 1-to-many relationship between sc_task and metric_instance? Only the metrics that relate to that task and the task ID are in the metric
I want to be able to show the related metrics on a relationship tab on the bottom of the task form.
2 ACCEPTED SOLUTIONS
Rohit  Singh
Hi @Scott29 ,
To create a related list showing all metrics related to the sc_task record you can do the following.
  1. Create a new Custom Relationship. System Definition->Relationships (Table Name: sys_relationship)
  2. Applies to -> sc_task (since you want to show related list on SC Task form)
  3. Query from -> Metric Table
  4. Use script section to build you query.
(function refineQuery(current, parent) {
	// Add your code here, such as current.addQuery(field, value);
	current.addQuery("id",parent.sys_id);
})(current, parent);
  • Now in the SC Task from view use "configure related list" and bring you Custom Relationship in the from using slush bucket.
Refer an example in Incident Form:
If my response helped, please mark it helpful and accept the solution so that it benefits future readers.
Rohit
Chaitanya ILCR
Giga Patron
Hi @Scott29 ,
if you have created a metric definition for SC task table
you should be able to see Metrics (just configure the related lists and add metrics)
Chaitanya
AndersBGS
Hi @Scott29 ,
i don’t quite understand your question due to metric and metric definition is to capture previous state or other field change over time. This is not a relationship between tables - so what if that your looking for and what is the business requirement?
