Setting Max length for a string field based on choice selection
tsam
Kilo Explorer
Hi -
I have a field in Service now that I need to limit the max length based on a selection from a drop-down list.
The field in question is a string field and I have been able to set the current max length to 25 characters, but I need this to be set to 11 characters based on 1 entry in my drop-down selection list.
Any assistance will be very much appreciated.
Thanks.
Please verify the element names in your script.
In demo008, I have this running as both a catalog client script and a client script on the incident form.
Here is the script:
var jt = g_form.getControl('u_job_type');//choice field
var sap = g_form.getValue('u_job_type');//selection value
if (sap == 'SAP Job'){
jt.maxLength = 11;
}else{
jt.maxLength = 25;
JordanLind
Please confirm which fields you are declaring in the variables.
The value in var jt should be the name of the string field that you want to control the length.
The value in var sap should be the name of the choice field.
tsam
Kilo Explorer
In case anyone else comes across this same question - below is the script I used to solve my issue:
function onSubmit(control, oldValue, newValue, isLoading, isTemplate) {
//Set number of characters required for field1 below
var mLength = 20;
var field1 = g_form.getControl('field1'); //field I needed to set maximum number of characters
var field2 = g_form.getValue('field2'); // my choice field selection drop down field
if (field2 == 'Selection' && field1.value.length > mLength){
g_form.hideErrorBox('field1');
g_form.showErrorBox('field1', 'ONLY a maximum of ' + mLength + ' characters is allowed in this field.');
return false;
else{
Thanks to everyone for your continued suggestions and assistance.
