‎02-01-2022 03:08 AM
I currently have a reference field that pulls information from a table - as you can see below there are multiple entries for A053501, but the second and third columns of this table will have differing information (This is fine).
When a user selects a value, say row 1 from above, the field 'All associated trays' should populate all of the entries with the same ID (A053501) just so the user can cross-check their selection.
I've read multiple threads about using javascript as a reference qualifier:
javascript:"u_all_associated_trays=" + current.u_unique_tray_id
and also using / setting dependent fields (I haven't been able to find this though)
Any help is appreciated.
‎04-26-2022 03:58 AM
This was actually re-designed to be achieved using a script include and by changing the field from a reference to a unique value field (This has a big performance impact considering how many values we are using - over 30k - but it will do for the time being)
‎02-01-2022 03:34 AM
Sorry
It should be current.variables.u_unique_tray_id
‎02-01-2022 03:37 AM
As you are using it on record producer variable.
Please use like below:
javascript:"u_tray_id=" + current.variables.u_unique_tray_id.u_tray_id.getDisplayValue();
Anil Lande
‎02-01-2022 03:44 AM
Ah this is a catalog item not a record producer
‎02-01-2022 03:29 AM
Please check type of field (column 1 ) on the reference table, if that is string then you need to use something like below:
javascript:"u_tray_id=" + current.u_unique_tray_id.getDisplayValue();
// here u_tray_id is name of 1st column in reference table
If you are trying to achieve this on record producer / catalog item then you need to use current.variables.u_unique_tray_id.getDisplayValue();
If 1st column is of reference type then you need to use:
javascript:"u_tray_id=" + current.u_unique_tray_id.u_tray_id.toString();
Please replace u_tray_id by the name of 1st column.
Anil Lande
‎02-01-2022 03:40 AM
Hi Anil,
I've set my reference qualifier to the following to no avail:
javascript:"u_tray_id=" + current.variables.u_unique_tray_id.toString();
javascript:"u_tray_id=" + current.u_unique_tray_id.toString();
toString because they are reference fields, but I've also tried getDisplayValue();
u_tray_type_id is the display column for the table
