‎02-01-2022 03:08 AM
I currently have a reference field that pulls information from a table - as you can see below there are multiple entries for A053501, but the second and third columns of this table will have differing information (This is fine).
When a user selects a value, say row 1 from above, the field 'All associated trays' should populate all of the entries with the same ID (A053501) just so the user can cross-check their selection.
I've read multiple threads about using javascript as a reference qualifier:
javascript:"u_all_associated_trays=" + current.u_unique_tray_id
and also using / setting dependent fields (I haven't been able to find this though)
Any help is appreciated.
‎04-26-2022 03:58 AM
This was actually re-designed to be achieved using a script include and by changing the field from a reference to a unique value field (This has a big performance impact considering how many values we are using - over 30k - but it will do for the time being)
‎02-01-2022 03:47 AM
‎02-01-2022 03:51 AM
Ah, I have corrected my previous reply, here is the table:
It is u_tray_id
‎02-01-2022 03:55 AM
Then your reference qualifier would be:
javascript:"u_tray_id=" + current.variables.u_unique_tray_id.u_tray_id.toString();
Anil Lande
‎02-01-2022 03:31 AM
Looks like you are using a catalog item:-
So use the below reference qualifier:-
javascript:"u_all_associated_trays=" + current.variables.u_unique_tray_id
Please mark answer correct/helpful based on impact.
