The Zurich release has arrived! Interested in new features and functionalities? Click here for more
Setting true/false flag for field using business rule
Mrman
Can someone please help with the below Business rule .When checking the logs it shows as rows retrieved: 0 . Please guide.
  var sci = current.u_sourceci;
  var rel = new GlideRecord('u_maximo_cmdb_ci');
  rel.addQuery('u_cinum', sci);
  rel.addQuery('u_hierarchypath', 'OPERATING SYSTEM \ AIX');
  rel.addQuery('u_cmdb_class_name', 'u_cmdb_ci_logical_partition');
  rel.query();
  gs.log("rows retrieved :"+rel.getRowCount());
  if(rel.next()){
  gs.log("HELLO IF");
  current.u_aixlpar = 'True';
})(current, previous);
Found it! It's definitely the backslash. It's a special character in Javascript that says 'the next character goes with this like \n, \t, etc.' To get it to work, change your query to use double backslash. That tells Javascript that the next character is a backslash, not a special character;
u_hierarchypath=OPERATING SYSTEM \\ AIX^u_cmdb_class_name=u_cmdb_ci_logical_partition
Sorry, I should have seen this earlier. It's been a crazy week.
23 REPLIES 23
Hi Chuck,
I tried with below as you suggested, still it returned 0 records.
  rel.addEncodedQuery('u_hierarchypath=OPERATING SYSTEM \ AIX^u_cmdb_class_name=u_cmdb_ci_logical_partition');
  rel.query();
  gs.log("Result :"+rel.getEncodedQuery());
Thanks for your patience.
I would try it two more times. One with just the first part of the query and one with the second. Something still tells me that backslash is trouble.
Test #1 use this:
  rel.addEncodedQuery('u_hierarchypath=OPERATING SYSTEM \ AIX');
Test #2 use this:
  rel.addEncodedQuery('u_cmdb_class_name=u_cmdb_ci_logical_partition');
Let me know how many records you get counted from each of those.
Hi Chuck,
I tested in both cases. below is the results.
Test #1 use this: rows retrieved :0
Test #2 use this:rows retrieved :50
Please guide.
Thank you. This proves my theory that backslash is being a problem.
Let me do a little testing to see what I can come up with for a fix out of this.
Ok Thanks Chuck. I will be waiting for your response. Please Guide as I am not able to find a solution for this.
