simple flow designer issue
ServiceNow Use6
I created a small Flow Designer flow, but it is running when I do the Test at the flow level, but not working otherwise. Kindly help.
Suman P.
2 ACCEPTED SOLUTIONS
miftikhar20
@ServiceNow Use6 ,
check run trigger field under flow trigger condition and set it to for every update. If you want it to run every time or anything else depending on your use case.
Thanks & Regards,
Muhammad Iftikhar
If my response helped, please mark it as the accepted solution so others can benefit as well.
Bhuvan
Giga Patron
@ServiceNow Use6
If you want the Flow to be run for every update or every unique update, change the Run trigger accordingly and not use Once.
Also check Flow is set to run as System rather than Run as User Who initiates the session. If it still does not work, share sample Flow execution log to understand why flow is failing.
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
yes, right.
Thanks & Regards,
Muhammad Iftikhar
Bhuvan
Giga Patron
@ServiceNow Use6
Bhuvan
nawalkishos
Hi @ServiceNow Use6  ,
Please check flow properties (Run as)like this-
and also check run trigger option -
If you found my response helpful, please mark it as helpful and accept it as the solution.
Thank you
Nawal Singh
Sarthak Kashyap
I tried your solution in my PDI and it is working fine please check below solution
In your flow make small change
Run Trigger - For every update
Result
Please mark my answer correct and helpful if this works for you
Sarthak
