Simple If/Else If Client Script Help
Adam Peterson
ServiceNow Scripting Experts,
I need help with my simple client script. It it OnChange and field is Knowledge Base.
What I want to happen is when the select their knowledge base, I want to assign their roles to it so only their department can see their knowledge base.
When I create a new article and put in Retail Tech in the Knowledge Base field - it does work as expected and assign the roles to 'retail technology'. BUT
if I put in Operations & Support - the roles goes to "retail technology" and not "operations_support". What am I doing wrong!?
Yes, I am new to scripting so please forgive me if I am missing something simple.
var gr = new GlideRecord("kb_knowledge_base");
  if (gr.kb_knowledge_base = "Retail Tech"){
  g_form.setValue("roles", "retail technology");
  else if (gr.kb_knowledge_base = "Operations & Support"){
  g_form.setValue("roles", "operations_support");
Thanks in advance!
Hi Adam,
Without doing a call to the server to find the name for your sys_id in-hand, I think you could use the following client-side:
        var checkValue = g_form.getDisplayBox('kb_knowledge_base').value;
        if (checkValue == "Operations & Support"){
This is for example only, please make sure to fill in with your correct values for comparisons, etc.
See how that works.
-Brian
Nevermind - I believe it is working correctly.
