Stage was not updating immediately while using flow designer
venkatesh tadip
Hi Team,
When we try to update the RITM stage value using the flow designer it was not updating immediately
we can see the updated stage after refreshing the page, but it should update without the refreshing the page
can you please suggest me the best solution
Thank you.
Hi @venkatesh tadip ,
I had checked and I was not able to add stage if there is no action after that.
So, use the below workaround.
Add the Stage, and Update the record with the same Stage - completed.
It works.
If this information helps you, Kindly mark it as Helpful and Accept the solution.
Najmuddin.
Najmuddin Mohd
Are you adding the stage using Update record action or by using the Add a stage feature.
We need to update the stage by using the second feature.
Select Flow stages from (...) more icon and select Requested item from choice list and click Add stages.
Then, hover above or below the action, you find Add a Stage and select the associated stage.
If this information helps you, kindly mark this post as Helpful.
Najmuddin.
venkatesh tadip
Hi @Najmuddin Mohd
When I am using parallel flow the add stage is not working so I have used the update record then I am setting the stage value so the issue is occurring when I am using the parallel flow can you please check my flow and correct me where i am doing wrong in it
It works.
Najmuddin.
