Sub-Flow Output Error in Flow?
Matthew Gill
I am calling Sub-Flows within a Flow. The Sub-Flows return [status] which is a True/False variable. The Sub-Flow tests correctly, but when it is called from the Flow the Sub-Flow completes, returns the appropriate output when looking at the subflow execution details, but the Flow execution details show an error for the Sub-Flow task.
It is as if the Sub-Flow output variable is not being passed back to the Flow. I have ensured that the variable types are the same, and the Sub-Flow is set to 'Wait for Completion). Any advice or guidance is appreciated. Thank you!
Matthew Gill
Alright... Support figured out what the issue was.
Even though the error was being shown on the Sub-Flow call, the issue was actually failing on the Update Record Action. Specifically, updating the 'Actual Start' field. I was updating to " return ( new Date() ); "; however, that field requires a String, for some reason, and was not giving a good Error Code. The workaround is to update to " return ( new Date().toString() ); ". Not ideal, but it works...
Thanks everyone for helping!
20 REPLIES 20
Done. Thank you all!
