UI Page not running processing script
grosch
Mega Expert
In my UI Page I've stuck this line to create the ok and cancel buttons:
<g:dialog_buttons_ok_cancel ok="return makeChanges()" ok_type="button" cancel_type="button" />
I then have this in the client script window:
function makeChanges() {
      var service = gel("service").value;
      if (!service) {
              alert("Please select a service to update.");
              return false;
      GlideDialogWindow.get().destroy(); //Close the dialog window
      return true;
When I hit OK, the window just goes away.   The code that I have in the Processing script never runs.   Is it because I listed an "ok" callback?   Basically I need to make sure the input is OK and then if it is do the work server side.
16 REPLIES 16
Hi Adam,
                      You find any fix for this ? I am having the same issue. Let me know if you found any fix for this.
Sai.
rodrigohiga
Hi Scott,
The properties tag "ok_type="button" cancel_type="button" are overriding the standard button's behaviour. Removing them the processing script will run.
I wont need the GlideDialogWindow.get().destroy();, neither.
