03-06-2025 03:05 AM
Hi! I am trying to take a field value from the form and use this to populate a field on a UI page with that value.
But it is not setting/getting the value. If i make my tags $[] I get a black reference value but if I use ${} I get no reference at all, I want to take the value from the record that is already populated.
<g2:evaluate var="jvar_cmdb_id" jelly="true">
var val = current.getValue('cmdb_ci');
val;
</g2:evaluate>
<g:ui_reference label="configuration_item" name="configuration_item" table="cmdb_ci" field="name" value="$[jvar_cmdb_id]" displayvalue="Testing" />
03-10-2025 03:03 AM
since you are in scoped app try this
<g:evaluate var="jvar_ci_sys_id" expression="RP.getWindowProperties().sysparm_ci_sys_id" />
<g:evaluate var="jvar_ci_display" expression="RP.getWindowProperties().sysparm_ci_display" />
03-10-2025 03:45 AM
Ankur! That worked - you genius! Thank you so much for all your support 🙂
