Upgrade required issue in Virtual Designer
Kri
I'm getting Upgrade required message when I try to create new Virtual Designer in Conversational Interface
Mark Roethof
Any luck with what I mentioned?
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
sidneynsjr88
Thanks for sharing this solution, Mark! I had the same issue on my PDI, and installing the Glide Virtual Agent [com.glide.cs.chatbot] plugin solved the problem. The "Upgrade required" message no longer appears.
