Urgent help on column label
dante3
Mega Guru
While I am moving update set on our test instance there is an issue with the column label.
I found out that it is not showing in the form layout because the column label is empty.
I tried to delete the column in test and create it again but it is still empty. I don't know why I can't update this column label.
Please help me urgently appreciate much!
I tried importing the xml from DEV but still got the same issue.
What I did is create a new field and delete the old one It works that way.
Thank you
I have also faced this kind of issue. i just removed the column and saved the form and added new column then it was working.
