‎04-09-2019 11:15 PM
And also out of 10 records 5 records caller id should be one user and the other 5 records should be another user.
As I am new to service now please let me know to code it
Thanks in advnace!
Scripting and Coding
‎04-10-2019 12:10 AM
Hi Shankar,
I have used the following script and the records are created.
for(var i = 0 ; i < 5 ; i++)
gr.initialize();
gr.caller_id = '62826bf03710200044e0bfc8bcbe5df1';
gr.insert();
gr.initialize();
gr.caller_id = 'a8f98bb0eb32010045e1a5115206fe3a';
gr.insert();
If the above code doesn't work for you, check for ACLs that might prevent you writing on the field. I ran the above code and records got created. See the attachment.
‎04-09-2019 11:49 PM
Use this
grIncident.setValue('caller_id', callerSysId[i]);
‎04-09-2019 11:48 PM
yeah buddy even I have done the same thing ,still the caller id is empty
‎04-09-2019 11:56 PM
Ah forgot the [i]. Try this:
var callerSysId = '0a826bf03710200044e0bfc8bcbe5d7a,be82abf03710200044e0bfc8bcbe5d1c';
callerSysId = callerSysId.split(',');
for(var i = 0; i < callerSysId.length; i++) {
var loopInt = 5;
for(var j = 0; j < loopInt; j++) {
var grIncident = new GlideRecord('incident');
grIncident.newRecord();
grIncident.insert();
‎04-10-2019 12:03 AM
No buddy still its showing empty,i dunno why?
‎04-10-2019 12:17 AM
