Using Regular Expression in Catalog Client Script to Limit Entry to 3 Digit All Numeric Entry
jmiskey
I am trying to verify that a Service Catalog field entry is restricted to exactly a three digit value (i.e. 051, 789, etc).  So I am trying to write a Catalog Client Script using Regular Expressions, but it is not working.  I keep getting an error message that says "There is a JavaScript error in your browser console" in the Service Portal when I enter an invalid entry in that field, like "AAAAA".
I tried two different methods, but neither one worked.  Here is the first:
Here is my second attempt, which is very similar to one we wrote for a Variable Set some time ago, but this one isn't working either.
Can anyone see what my issue is?
jmiskey
Thanks for the attempts.  Playing around, we finally figured out something that works.  We used this code to restrict it to numbers only:
	var number = g_form.getValue('pbp_id');
	if(!number.match(/^\d{3}/)){
		alert('Please enter only a 3 digit number');
		g_form.setValue('pbp_id','');
And then we used the following Variable Attributes to restrict the length,
max_length=3,min_length=3
Akash69
Giga Contributor
This proved to be extremely helpful.  Thank you.
lmseco
Mega Expert
jmiskey,
Depending on the version of ServiceNow, you can also define a regex variable instead of using onchange scripts...
Define a regular expression for a variable
