Values from multi row variable set not populating in knowledge article
11-21-2023 07:57 PM
I have a requirement where I need to create a Knowledge article when a form is submitted from a record producer on the portal. I have used a Multi-Row variable set in that record producer so that users can add multiple rows and information as per their need. I want to populate those rows filled by a user in a Knowledge article. I have created a flow which will create a knowledge article once it is approved. To populate record producer values in the knowledge article, I have written an after update Business rule:
11-22-2023 08:23 PM
Hi @amolpawar ,
I trust you are doing great.
You can refer below video to understand how Multi Row variable works:
11-23-2023 02:38 AM
Hi @Tai Vu,
Thank you so much for your reply. It was very helpful for me. As I already posted above, It is working fine now with the help of the Business rule. Your suggestions and insights really helped me.
Thank you.
Hi @Amit Gujarathi,
Thank you for your time and such a informative and helpful video.
Thank you,
Amol
