Variable Currency Widget on Record Producer is way too small
Tobi_01
 Hello All,
Im Having a issue with using a Item on a Record Producer.
I am using Type „Custom with Label“ for a variable that should Display the variable currency Widget.
It is displaying it, but just way too small, it is Stored inside a 2 Column container, but just using around 10% of the available Space.
can someone help me with that?
Sandeep Rajput
@Tobi_01 I faced the similar issue in the past, Since OOTB Variable Currency widget is read only. You need to make a clone of it and use that clone as a Custom with Label variable on your Record Producer.
Also, on your cloned widget, you need to add following CSS in the CSS field.
input.currency{
  text-align: right;
  width:auto;
Hope this helps.
Thank you so much @Sandeep Rajput
