Which rule will be executed first row level ACL or field level ACL rule ?
Ketan Pandey
HI All,
I am new to Servicenow ,I was going through the training and i am stuck with bellow doubts
As per documention, Field level ACL then Table Level ACL will be executed but when i checked the Security log ,I could see that Table level ACL executed first.
Thank You,
Ketan
13 REPLIES 13
As per bellow sevicenow documentation also ,Table level and then Field
https://docs.servicenow.com/bundle/sandiego-platform-administration/page/administer/contextual-security/concept/acl-rule-types.html
Harish KM
Hi first it will check table and then fields refer diagram here. With out access to the table how can you give access to field?
Appli
Hi, it is written in the documentation I believe:
Record ACL rules are processed in the following order:
  • Match the object against table ACL rules.
  • Match the object against field ACL rules
So, table ACL comes first.
Hope it helps
Ravi Gaurav
Hello @Ketan Pandey
look the thread :-
This will give you a full picture of what is the hierarchy for ACL's
