\$(window).scroll doesn't work for widgets?
stryker129
Mega Guru
Hi guys,
As per our requirements I need to do sticky header for this div:
<div id="header-2">
              some content of sticky header
      </div>
<div id="container">
        some big-big text here
</div>
Client script:
$(window).scroll(function () {
      if( $(window).scrollTop() > $('#header-2').offset().top && !($('#header-2').hasClass('posi'))){
          $('#header-2').addClass('posi');
      } else if ($(window).scrollTop() == 0){
          $('#header-2').removeClass('posi');
and css:
#header-2{
      background: #eeeeff;
      width: 100%;
      height: 50px;
#container{
      margin-top: 50px;
.posi{
      position:fixed;
        margin-top: 0;
      top:0;
I've got it from this example:
javascript - Sticky header after some scrolling? - Stack Overflow
But it doesn't work: scroll event didn't fire.
Thoughts?
Hi jued0001
Thanks for making me understand about this issue
Move to header functionality works for only container not for columns.
So here is the solution which I tried, add below CSS to your custom widget
.stuck {
      position: fixed;
      display: inline-block;
      overflow-y: auto;
and add "stuck" class to custom widget HTML div.
-Check this if it helps..
Can you give more detail for this:
"and add "stuck" class to custom widget HTML div."
I tried the following but it's not scrolling/sticking:
I'm still learning this kind of stuff.
EDIT:   I moved the </div> to the outside of everything else and that did make it stick.   It looks weird though because it sticks right where it is - in the middle of the screen.   Is there a way to make it stick to the top of the screen (or the bottom of the widget above it)?
After scrolling:
I wanted to drop one more post in here which makes this work as I wanted it to, after borrowing what was setup for Order Guides for us by a vendor.
In your widget, add the following -
Link Function
function(){
setTimeout(function(){
$(function() {
var $sidebar     = $(".submit-panel"),
$window       = $(window),
$body           = $('section.page'),
offset         = $sidebar.offset(),
topPadding = 15;
$body.scroll(function() {
if ($body.scrollTop() > 20) {
$sidebar.stop().animate({
marginTop: $body.scrollTop()
marginTop: 0
},50);
CSS
.submit-panel {
HTML Template
Add this to the top and a matching </div> at the bottom
<div class="submit-panel">
stuff presented in your widget
</div>
JC Icaro1
In case this helps someone, another option is to use [position: sticky].
See below example.
https://codepen.io/nyctophiliac/pen/xpmpyp
