Work Note field is not editable
laszlobolya
Kilo Expert
May you can give me some advice I`m lost again
there is a custom table within application, the table extended from request table. All looks so far, expect the work notes field is not editable . see screenshot.
What is done: With ACL read and write right for all fields for the supporter role. Also, I tried to add read and write right sepearately to work?note field.
Same result Do you have any idea why it could be? With admin account I can see work notes and add comments as for another tables, in one block with check box selection. Thanks!
I got it.
Configure the form layout and just below additional comments add 'Activities (filtered)' It will be in the lower part of the slush bucket list.
Let me know if it worked.
Ahh! Seems to be working now. I have added already for sure the activities. However I had three availabl on the left, just selected one. I remember I was playing with activity formatter to customize what activity to be displayed on activity filters. It was not so trivial because of the scope application.
So can`t really tell you the exact issue, but after playing a bit more with the activity fomatters on Form Layout the issue seems to be solved..
Thanks!
