Mapping reference variable to system variable
Options
02-08-2024 09:01 PM
I have a catalog item with variable User Id and i added this variable into the sc_request table as a reference field.
Now I have to map my variable u_user_id to the user_name field present in sys_user table
How do I assign this through script in workflow. Any help is provided.
Community Alums
Options
02-08-2024 09:21 PM
Hi @Ramya SL ,
Question is not clear..Are you trying to create new user using catalog item.. or are you trying to update the sys_user record.
Please elaborate the requirement
