Parsing the response body from rest step... help
Options
10-12-2023 03:25 AM
Input response body i am getting from a rest step and response body is a string field. I am getting undefined at the gs.info step and excution goes into ELSE everytime. What am i doing wrong
var parsed_response_body = JSON.parse(inputs.response_body);
gs.info("Response res1 *****" + parsed_response_body.status + "*****")
if (global.JSUtil.notNil(parsed_response_body.status) && (parsed_response_body.status).contains('ERROR')) {
outputs.err_code = parsed_response_body.uniqueErrorCode;
outputs.err_msg = parsed_response_body.message;
outputs.ret_code = "ERROR";
outputs.err_code = 200;
outputs.err_msg = '';
outputs.ret_code = "SUCCESS";
})(inputs, outputs);
Logs:
Response res1 *****undefined*****
Options
10-12-2023 03:50 AM
Hi @AbineshM,
I think response is in Object format, try to check what is the typeof inputs.response_body.
if it return string then we need to parse
if it return object then your no need to parse the inputs.response_body
Try to access the key
var response= typeof inputs.response_body;
gs.info('check type of variable : ' +response); // if it return string
gs.info("Response res1 *****" + response.status + "*****")
If my response helps you to resolve the issue close the question by Accepting solution and hit thumb icon. From Correct answers others will get benefited in future.
T Mohan.
