EA Workspace – How to Export Enterprise Modeling Diagrams Outside UI Builder - Need PDF from portal
imranaalam
Hello Everyone,
I’m looking for guidance and solutioning support for a requirement related to ServiceNow Enterprise Architecture (EA) Workspace, specifically around Enterprise Modeling and Visualization and diagram export.
Background
In EA Workspace, under Enterprise Modeling and Visualization, users can:
  • Create new diagrams
  • Update existing diagrams
Each time a diagram is created or updated:
  • A record is created or updated in the Diagram Instance OOB table
  • The diagram structure is stored as JSON
When opening a diagram record:
  • There is an “Open in Builder” option
  • This opens UI Builder
  • UI Builder provides an OOB “Download” button
  • Clicking the button downloads a PNG snapshot of the diagram
Technical Observation
  • The OOB Download functionality internally uses a third‑party framework: GoJS
  • GoJS consumes the stored diagram JSON and generates the PNG image
  • The implementation details (APIs, functions, input parameters) are not exposed
  • The GoJS integration appears to be restricted for ServiceNow internal use only
Business Requirement
The requirement is to create the same diagram download capability outside UI Builder, specifically:
  • Provide a Download option in a Portal / custom UI
  • Generate a 3‑page PDF report related to the diagram record:
    • Page 1: Record metadata
    • Page 2: Diagram snapshot (PNG)
    • Page 3: Additional related details / relationships
The key requirement is that the diagram image should match exactly what ServiceNow generates using the OOB Download button in UI Builder.
What I’ve Already Tried
I’ve explored multiple approaches, but none have provided the expected outcome:
  1. Tried to access or reuse GoJS APIs used by ServiceNow
    • Not possible due to restricted/internal implementation
    • Unable to determine which inputs are passed or which functions are invoked
  2. Tried recreating the diagram manually using the stored JSON
    • Not successful
    • Diagram rendering is not purely JSON‑driven
    • JSON contains system data (sys_ids, internal references)
    • Additional internal rendering logic seems to be involved
  3. Tried automation using RPA
    • Not feasible or reliable
    • Not suitable for a production‑grade or maintainable solution
Despite multiple attempts, I’m unable to produce an identical diagram image outside UI Builder.
What I’m Looking For
I’d appreciate guidance from anyone with experience in:
  • ServiceNow EA Workspace internals
  • GoJS (especially image export mechanisms)
  • Identifying a supported workaround or architecturally sound approach
yogesh41
Will you please provide high level use case or user journey where generating pdf report for diagram or downloading diagram as pdf will be used ? This will help us identify any available APIs
Yogesh
The client requires the ability to export EA diagrams from the Portal, combined with other related details. To achieve this, we explored replicating the out‑of‑box download functionality available in UI Builder. However, the underlying APIs and functions used for this feature are restricted and not accessible for customization or reuse.
