Changing Qualification Group for Work Orders
WR2
I am new to ServiceNow and was tasked with something that I can't seem to figure out.
Currently, when a user clicks on a catalog tile named "Facilities" from the Service Portal and submits the form, a work order is created which is automatically assigned to the Qualification group named "Facilities Distribution Center".
The request is to change the Qualification group that it defaults to, from "Facilities Distribution Center" to "Facilities Headquarters".
So I just need to change the Qualification group that all work orders are automatically assigned to.  Thought it would be an easy task but I can't seem to find a way to do it.
Thanks!
SalmatO
To change the default Qualification group, you’ll need to modify the logic that assigns the group when the work order is created. This can typically be handled by updating either the configuration or a business rule. You will need to find the assignment logic, check field service catalog or business rules
KKrabbenhoft
Good morning, @WR2 I wanted to update you on my findings regarding the onSubmit notification. Turns out when territory planning is enabled so is a business rule called validate "Validate Qualification Group " if since I do not have any valid qualification groups (yet) this business rule was flagged and hence the error. I turned this off since my use case does not call for this to run.
Let me know if this helps you a bit.
Thank you, this is good to know if I run into this in the future!
My situation was a little different, I just had to change the sys_id to the correct Qualification group on a business rule.
