Automatic creation of Issue for GRC Metrics
SUSMITHA KRISHN
I have a requirement to generate issue automatically when the value in the metric data task is having the value of red threshold.
According to current functionality I understood that when indicator fails then issue can be generated automatically with issue source as indicator failure. But we are using GRC Metrics in our case.
1. In similar way like Indicators, does GRC Metrics have a functionality to generate issue automatically with issue source as metric.
2. Also, please help me understand the OOB functionality of how the issues are generated automatically for control attestations or indicator failures
Ash70
Hi @Vaisakh Krishna
We have just installed GRC: Metrics v22 into a lower environment and on first glance it looks like we are going to have to recreate all of our Metric thresholds as the old ones don't calculate the threshold rating anymore.
This will be a lot of work as we have lots of metrics. Can you please confirm that is what we will need to do?
Many thanks
Karthik_V
Hi @Ash70
The old thresholds are automatically migrated to the new thresholds and they calculate the rating in the same way as it used to be before. Please can you provide details with screenshots on the issue which you are facing?
Ash70
Thanks for the assistance @Karthik_V.
Please see attached screenshot. I completed the Metric Data Task however the threshold rating field on the metric data table remains blank.
Many thanks
Ash70
Just to close this out, it was a recognised bug that was resolved after a fix (migration script) provided by ServiceNow in the HI ticket. No need to recreate all existing metric thresholds, the migration script will do it.
