‎07-30-2025 01:28 AM
During control attestation, I want issues created when a Control is "Not Applicable" in servicenow. I know OOTB it is via Business Rule and OOTB script include that creates issue record, when the question answer is selected "No" and it sets non compliant.
‎07-30-2025 12:25 PM
Thanks for the clarification.
Based on your information:
- Search for the "GRCAssessmentUtils" Script Include
and the "GRCAssessmentUtilsBase" Script Include. - You can overwrite or extend the corresponding functions of the "GRCAssessmentUtilsBase" Script in the "GRCAssessmentUtils" Script.
- Please note, that you should never change the "...Base" Script!
- A few of the functions you are looking for:
- _createAttestationIssue
- _evaluateControl: (somewhere around line 1177 coud be interesting for you)
Another way that might be easier and also work fine, is to create a
new Attestation Template and define a Choice Field with "Yes" "no" "not appliccable" where you define ony "Yes" as correct answer.
Would be great if you mark the answer as helpful and correct if I could help you out.
‎07-30-2025 12:58 PM
I am unable to modify this script. It's read only and protected.
‎07-30-2025 01:25 PM
The script is not read only and protected if: No ACL (or else) is running against you and you are in the right application scope.
Means: If you cant work on it something blocks you, and that is usually not the case, you could even change the base script if you wanted to (DONT!).
‎07-30-2025 01:26 PM
This one worked like a charm, thank you.
new Attestation Template and define a Choice Field with "Yes" "no" "not appliccable" where you define ony "Yes" as correct answer.😊
‎07-31-2025 07:52 AM
Welcome, glad I could help
