How does ServiceNow's GRC product help for a SOC 2 audit?
kathymorris
We are going through a SOC 2 Audit. How does ServiceNow's GRC products help us to better position ourselves for the SOC 2 Audit? Which products within the suite are related to the SOC 2 Audit?
How are other companies leveraging ServiceNow's GRC for SOC 2?
Kathy
jing3
Mega Guru
Policy and Compliance:
select controls required by SOC2 (UCF integration)
Assign controls to owners
Attest controls
Gather evidence of control effectiveness
Audit:
planning engagement
gather the evidence needed directly from P&C, or additional task
Create reports
More examples (not SOC 2, but are good examples of how GRC being used to meet a given set of requirements):
Check out GRC: NIST RMF Use Case Accelerator, GRC: NIST CSF Use Case Accelerator and GRC SOX Content PackGRC SOX Content Pack
jing3
Mega Guru
Attest controls
Audit:
planning engagement
Create reports
Emile ten Hoor
Hi Kathy,
A large number of our customers use ServiceNow as ITSM tool. The information used for a SOC2 audit is primarily incident management logs and the change management process. Within these processes the existence of procedures are audited (are controls correctly designed in accordance with the descriptions in the SOC2 report) and the operational effectiveness of procedures is audited in which the contents of incidents are reviewed against the control objectives.
We feel that ServiceNow could be a more integrated tool to achieve automated auditing in which evidence is automatically audited and exceptions are automatically identified.
If you require more information on SOC2 or would to like to get met information on SOC2, I can manage that our learning partner who provides a SOC2 course helps you further on this subject.
