If Q1 is Yes and Q2 is No and Q3 is No then i need to display q4 with some value .
12-23-2024 09:56 PM
Hello Everyone,
If Q1 is Yes and Q2 is No and Q3 is No then i need to display q4 with some value . Like this i have 5-6 probability scenarios. i have used Client scripts. How ever few scenarios are not working and for few the Q4 value is not getting cleared. Can anyone help me on this?
Hopefully looking for possible solution, Thanks in advance.
12-24-2024 12:46 AM
I hope I have provided a thorough answer to your question. I'm confident that with your developer skills, you can take it further from here.
12-24-2024 01:47 AM
12-24-2024 09:34 PM
Hope you are doing good.
12-29-2024 06:41 PM
12-23-2024 10:06 PM
Hello @irfan12 ,
Could you please provide more details about your requirement?
I believe a single client script might not be sufficient since Q4 depends on multiple questions. In this scenario, a UI policy would be more effective.
Please mark this as "correct" and "helpful" if you feel this answer helped you in anyway.
Thanks and Regards,
Ashish
