Need some information on Risk and Compliance score roll ups and hierarchies
somjyotisinha
Hi all,
I have a few queries regarding entity hierarchies and risk and compliance score roll ups. Could anyone please answer them? Thanks in advance.
Question 1:
Is there a way to have multiple entity class hierarchies on the same instance?
For example, is it possible to have both of the following hierarchies on the same instance:
Entity Class A (Top level Parent) - Entity Class B (Child) - Entity Class C (Grandchild)
Entity Class D (Top Level Parent) - Entity Class E (Child) - Entity Class F (Grandchild)
Question 2:
We are using classic Risk Management (not Advanced Risk Management). Does Risk Score roll up work for it, if we have an Entity class hierarchy in place?
How can it be set up, and where are the rolled up risk scores located?
Question 3:
Compliance scores are getting rolled up at the Entity Type level based on the entities. Are compliance score rollups also available at the following levels:
Entity level - Is the compliance score for an Entity rolled up, based on scores of its downstream entities? If this feature is available, how can it be set up?
Entity class level - Is the compliance score for an Entity class calculated based on its entities? If this feature is available, how can it be set up?
I understand. Thanks for all the help and the detailed explanations, Sandeep.
I might need a custom solution for this one.
