06-20-2022 07:30 PM
Can someone please guide me for the following scenario I am trying to setup .
I have a control that no user should have admin rights .
I am now designing an indicator for this control .
This will be a manual indicator , but in supporting data i want to query sys_user table for all users with the admin role . Or if a particular user is my entity for the control , I want to show all the roles for that particular user as supporting data in the indicator results .
My doubt is , how to frame the query in the indicator template to fetch this data
thanks in advance
06-21-2022 02:55 AM
Hi Gary,
Then in this case, you need to change the Method from 'manual' to 'script' and build a below script to query the entity (user record) present in a control to the sys_user_has_role table and check if the entity record is having admin role or not. If there are records then Indicator should fail else it should pass.
Below can be the script
var grSUHR = new GlideRecord('sys_user_has_role');
grSUHR.addEncodedQuery("sys_id=+current.profile^role.name=admin"); // Here current.profile will get the entity sys id from control table
grSUHR.query();
if(grSUHR.next())
result.passed = false;
else
result.passed = true;
result.supportingDataIds = [grSUHR.user.user_name, grSUHR.user.manager, grSUHR.user.roles,grSUHR.user.location];
Note - I have not checked the script on actual indicator template but it should work in your case.
Please Mark ✅ Correct/helpful, if applicable, Thanks!!
Sulabh Garg
06-21-2022 03:11 AM
thank Champ
06-21-2022 04:48 AM
I am glad it worked. 🙂
