05-24-2019 12:35 PM
We have HR case management setup in our organization. Someone has asked if an approval can be added to a record producer form from the HR service portal.
I don't think we're task based so, would it be difficult to add an approval process to specific record producers? Would it just be a matter of adding a workflow to any given record producer? How would the case lifecycle look?
Case and Knowledge Management
06-18-2019 08:23 AM
Per ServiceNow, the workflow that checks for approvals was skipping over the evaluation.
In the HR Service Activities workflow under "Is there an approval step" stage, the second if statement was missing some additional conditions:
While the version I had only contained:
if (serviceTemplates.next()}
return 'yes';
It should have been:
if (serviceTemplates.next()) {
workflow.scratchpad.serviceActivity = serviceTemplates.getUniqueValue();
return 'yes';
I don't believe this was modified by anyone and may have been a bug but this is what ServiceNow had modified to make it work.
06-03-2019 07:57 AM
I'm not exactly sure what you're asking however the manager is listed in the HR profile.
06-02-2019 11:51 PM
That is correct place to add the approver, Please make sure manager is not missing in subject person user profile.
06-03-2019 07:57 AM
I've verified that the manager is listed.
06-18-2019 08:23 AM
return 'yes';
return 'yes';
