auto approval from previous approval in flow designer.
AJAYKUMAR G
if approver is same from previous approval proceed for next approval in flow designer
9 REPLIES 9
3 stages approval from flow designer
1 approval ,approver is xyz
2 approval ,approver is xyz
if both approver are same directly go stage 3 approval
stage 1 approval approved
stage 2 approval skipped (same approver stage 1 )
stage 3 approval waiting
Do a lookup between the two approvals. Check if the approvers are the same and if not, create the new approval. If so, skip that step.
sys_id only different.
If the sys_id of the first approver isn't the same as of the second, they are not the same approver.
@AJAYKUMAR G
so what did you configure to compare?
what's not working?
