Best practice for customizations? (Scopes, Cloning and Update Sets).
I am about to Implement the HRSD Integration with SuccessFactors.
It will require a significant amount of customization to add new Fields, new services for importing additional tables, new flows for Full and delta loads and new flow actions which can use a different alias for different environments (dev, test etc). .  I expect I will be making modifications in maybe 5 or 6 different Applications scopes.  I have three interrelated questions about best practice.  What is your experience with the following?
A.  What option do I use for managing scopes:
  1. Do I create a new custom Scope and put all my customization is the new scope?   What about RCAs?
  2. Do I use the global Scope only?
  3. Do I put my customizations in the appropriate 5-6 scopes?  (harder to manage update sets)
B.  To clone or not to clone?
  1. Do I clone items (such as flows)?
  2. Or edit existing items?
C. Managing Update Sets
  1. Do I use Merge update Sets?
  2. Create use Batch Update Sets?
  3. Do I created Update Set versions and then use the "Copy Update Set Utility" when creating a new version.
Possible Solution
I did find this post.
https://www.servicenow.com/community/now-platform-blog/best-practices-for-using-the-flow-designer/ba...
Which suggest a Best practice is:  A.1 (custom Scope);   B.1 (clone so you get updates); and C.3.
Copy Update Set Utility:  see:  https://developer.servicenow.com/connect.do#!/share/contents/3673648_copy_update_set?v=1.5&t=PRODUCT...
Thanks for your reply.  I know there is no "right" answer here.  Please see my response to Julians's post below.
