Calculate subtracted values of two fields and display result in 3rd field
Vaishali 11
I have a requirement where there are 4fields- field1, field2, field3 & field4. In field3 it should display the subtracted value of field2-field1. in field4 it should display (f2-f1)/f1.
How can this be achieved?
Thanks in advance!!
2 ACCEPTED SOLUTIONS
Hi there @Vaishali 11 , Here is the catalog client script you should write for the portal. I have tried this in PDI and it's working perfect as per your requirement.
Script : onChange();
    var f1 = g_form.getValue('f_one');
    var f2 = g_form.getValue('f_two');
    var sub = f2 - f1;
    var div = (f2 - f1) / f1;
    g_form.setValue('f_three', sub);
    g_form.setValue('f_fr', div);
Refer this SS as well.
If this answer helps you in any way make sure to Mark this as accepted solution and give a thumbs up this will also benefit others as well.
Regards.
Saurabh V.
@Vaishali 11
try this
-> 1 onChange catalog client script on field 2
-> another onChange catalog client script on field 1
-> Use parseInt() to convert string to integer
    var val1 = parseInt(g_form.getValue('field1'));
    var val2 = parseInt(g_form.getValue('field2'));
    var sub = val2 - val1;
    var div = sub / val1;
    g_form.setValue('field 3', sub);
15 REPLIES 15
    var sub = f2 - f1;
Regards.
Saurabh V.
Hi @svirkar420 ,
I have tried the above script as well but still getting the same error.
Thanks in advance!!
@Vaishali 11 , can you share a screenshot of your script please, this should have been working fine and it is working on my PDI.
Saurabh V.
Please find the attached screenshot, getting the same error on portal
Hi @Vaishali 11 , I can see in the screenshot above you have declared the 'g_form' method incorrectly, in the SS its gForm, it should be 'g_form', update that and then try the script I provided.
If this helps don't forget to accept this answer as solution and give a thumbs up as well, to appreciate my efforts.
Best Regards,
Saurabh V.
