10-23-2025 01:36 AM
I have a requirement where there are 4fields- field1, field2, field3 & field4. In field3 it should display the subtracted value of field2-field1. in field4 it should display (f2-f1)/f1.
How can this be achieved?
Thanks in advance!!
10-23-2025 04:47 AM
Hi there @Vaishali 11 , Here is the catalog client script you should write for the portal. I have tried this in PDI and it's working perfect as per your requirement.
Script : onChange();
Refer this SS as well.
If this answer helps you in any way make sure to Mark this as accepted solution and give a thumbs up this will also benefit others as well.
Regards.
Saurabh V.
10-23-2025 05:20 AM
try this
-> 1 onChange catalog client script on field 2
-> another onChange catalog client script on field 1
-> Use parseInt() to convert string to integer
var val1 = parseInt(g_form.getValue('field1'));
var val2 = parseInt(g_form.getValue('field2'));
var sub = val2 - val1;
var div = sub / val1;
g_form.setValue('field 3', sub);
g_form.setValue('f_fr', div);
10-23-2025 05:47 AM
thanks @svirkar420 , working now.
10-23-2025 05:58 AM
I don't think it will work as you are trying to subtract 2 strings.
Could you share the results?
10-23-2025 05:20 AM
try this
10-23-2025 05:26 AM
Hi @Ankur Bawiskar ,
I tried this approach as well, but not working
10-23-2025 05:46 AM
share screenshots of your client script config,
share your script, share what error you are getting
without this we can't help
