Calculate subtracted values of two fields and display result in 3rd field
Vaishali 11
I have a requirement where there are 4fields- field1, field2, field3 & field4. In field3 it should display the subtracted value of field2-field1. in field4 it should display (f2-f1)/f1.
How can this be achieved?
Thanks in advance!!
2 ACCEPTED SOLUTIONS
Hi there @Vaishali 11 , Here is the catalog client script you should write for the portal. I have tried this in PDI and it's working perfect as per your requirement.
Script : onChange();
    var f1 = g_form.getValue('f_one');
    var f2 = g_form.getValue('f_two');
    var sub = f2 - f1;
    var div = (f2 - f1) / f1;
    g_form.setValue('f_three', sub);
    g_form.setValue('f_fr', div);
Refer this SS as well.
If this answer helps you in any way make sure to Mark this as accepted solution and give a thumbs up this will also benefit others as well.
Regards.
Saurabh V.
@Vaishali 11
try this
-> 1 onChange catalog client script on field 2
-> another onChange catalog client script on field 1
-> Use parseInt() to convert string to integer
    var val1 = parseInt(g_form.getValue('field1'));
    var val2 = parseInt(g_form.getValue('field2'));
    var sub = val2 - val1;
    var div = sub / val1;
    g_form.setValue('field 3', sub);
15 REPLIES 15
Ankur Bawiskar
@Vaishali 11
it's an easy requirement.
what did you start with and where are you stuck?
