Field highlighting does not work for reference fields in workspaces list view
08-12-2026 06:25 AM
Field highlighting does not work for reference fields in workspaces list view in HR Agent Workspace but works for Incidents in SOW. Any ideas how to highlight reference fields in the list view?
08-12-2026 06:35 AM
for list view UX Highglighted value does work, share your configuration
Example: caller_id reference field on INCIDENT shows star icon
08-12-2026 06:51 AM
It is same as the configuration in the screenshots that you have attached. Its basically out of the box function.
08-12-2026 07:13 AM
then it's not working for your table and field?
08-12-2026 07:28 AM
@KushalaM0405144 this is known issue for reference fields please check bellow KB.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB2101859
Please mark my answer correct and helpful if this works for you.
