Flow designer error : JSON string
Averyy
I am working on a flow to be triggered when a supervisor approves the submission of a document from a new hire.
I keep getting this JSON error
Any suggestions? (I am not the most exp dev at the moment)
9 REPLIES 9
-O-
JSON.parse expects a string as parameter, and fd_data.trigger.current.payload (assuming such a field exists) is not a string, but an object (of "type" GlideElement).
This situation makes JSON.parse freak out.
All in all I'd try
var payload = fd_data.trigger.current.payload.nil() ?
	JSON.parse(fd_data.trigger.current.payload.toString());
again assuming field/column payload does exist and it contains a valid JSON.
This will make payload end up being either an "empty" object or the object in the JSON.
Sandeep Rajput
@Averyy Update the script as follows and see if it works.
var payload = JSON.parse(fd_data.trigger.payload);
Thank you! This created an error when testing
VishalB06557037
Hello @Averyy
If possible can you share snapshot of flow and snapshot of payload field & payload data ...??
Vishal Birajdar
ServiceNow Developer
- Socrates
Averyy
Hello all apologies when I created this post I left out a lot of info. I have since recreated the post.
https://www.servicenow.com/community/hrsd-forum/flow-designer-error-json-string-quot-remake-quot/td-...
