flow designer
kali
I created a flow in flow designer that whenever case is closed complete and additional comment is added in the case , a new case should be created . The case creation is working as expected. I modified the flow to copy two more additional field from parent case to child case. I am able to see the two fields value in the list layout but in the form layout the two fields are not showing up. I tried everything from clearing system cache , browser cache, checking ui policies and client script . Please help me on this. Thanks in advance.
SunilKumar_P
Hi @kali, Do you see the data in those two fields in list view? Can you also check if data policies exist?
Sunil
