11-02-2023 01:08 AM
Actually i need to create flow designer for the HR task and multi level approvals on HR cases, but i am new to the flow designer
the flow like
1. firstly need to create hr task when case is created and the assigned to manager
2.once task closed then first approval need to trigger to HR group
3.once first approval was approved then 2nd approval needs to trigger to Business unit
4.once 2nd approval is approved and if one of the field (master level) is true on the case form then 3rd approval needs to trigger to line manager
5.after that last one task needs to created
If any of the approval rejected then flow will end and mark as incomplete
Actually i am able to do create first task after that i am not able to go forward
Please help me on this
Deepika
11-02-2023 03:27 AM
Hi @Deepika61
Within the Create Task action you can check the Wait checkbox.
This pauses the flow until the task is closed.
11-02-2023 02:23 AM
Hi @Deepika61,
You can use the 'Ask for Approval' Action to start with the first approval. After that, keep doing the same logic based on your requirements.
If you get stuck, please let me know exactly where you are running into issues.
11-02-2023 02:38 AM
i have tried like below but it won't meet my requirement actually, but i want first task created and then closing of the task approval needs to trigger
11-02-2023 03:27 AM
Hi @Deepika61
