How to Filter Users with HR Profiles
pjftenorio
Hi, I've already created an Advance Reference Qualifier in Variable Set for Opened For/ Subject Person referenced to table [sys_user] and to filter only users with HR Profiles but since this is a query, loading of users in drop down takes 3-5 seconds before showing and it is a bad user experience.
Is there any way to optimize it?
Variable setup:
Script Include:
var NMHRProfileUtils = Class.create();
NMHRProfileUtils.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
	initialize: function() {},
    getListUsersWithHRProfile: function() {
        var ids = [];
        var gr = new GlideRecord('sn_hr_core_profile');
        gr.addNotNullQuery('user');
        while (gr.next()) {
            ids.push(gr.getValue('user'));
        if (ids.length === 0) {
            return 'sys_id=NULL';
        return 'sys_idIN' + ids.join(',');
    type: 'NMHRProfileUtils'
Updating my reply. It works now
Here is the setup that we've come up in the variable under variable set.
Then in script on record producer, we use the dot-walk as @palanikumar had mentioned.
Abhishek_Thakur
Hello @pjftenorio ,
I agree with @palanikumar , currently I am working as a solution architect on HRSD module, and I would recommend making the reference field directly to the HR Profile (sn_hr_core_profile) and apply the simple reference qualifier filter, attaching the below screenshot for your reference.
If my response helps you, please mark this as accepted solution and give thumbs up.
Abhishek Thakur
Ankur Bawiskar
@pjftenorio
Since you made the variable point to HR Profile table, you should remove any ref qualifier applies
share your variable config screenshots.
