03-15-2021 05:45 AM
How to create multi row variable set in the case form. It has to be with 3 columns and n number of rows on addition.
Could anyone please suggest how it can be created in case UI .
HR Service Delivery
03-15-2021 07:25 AM
You can use this script in before insert BR of Case Table
// Add your code here
var mrvs = current.variables.mrvs; // your MRVS variable name here
var arr = [];
var parser = new global.JSON();
var parsedData = parser.decode(mrvs);
for(var i=0;i<parserData.length;i++){
var obj = {};
obj['Date'] = parsedData[i].date.toString(); // give here the mrvs variable name of date
obj['Incident Details'] = parsedData[i].incident_details; // give here the mrvs variable name of incident_details
arr.push(obj);
current.setValue('u_name_value', JSON.stringify(obj)); // your Name-Value field name here
})(current, previous);
03-15-2021 07:25 AM
var arr = [];
var obj = {};
arr.push(obj);
03-15-2021 10:10 PM
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
03-16-2021 02:06 AM
03-16-2021 04:53 AM
you can add logic to add counter
var arr = [];
var obj = {};
var dateKey = 'Date' + parseInt(i+1);
var incidentKey = 'Incident Details' + parseInt(i+1);
obj[dateKey] = parsedData[i].date.toString(); // give here the mrvs variable name of date
obj[incidentKey] = parsedData[i].incident_details; // give here the mrvs variable name of incident_details
arr.push(obj);
06-14-2022 11:44 PM
can u give me the script for this?
