How to trigger an event from flow designer for HR case?
Deepika61
Actually i have created a flow designer for approval for case, when ever case created it goes manager approval, when ever it rejected i need to send an email notification to user?
So need to trigger event from flow?
Please help me to complete this
Deepika
Hi @Deepika61 ,
When u say unable to select means is it not editable or the event which u created is not available in the list?
Danish
@Danish Bhairag2
its editable only, but i can't find the event which is ootb , the list which appears it does shows that event
Peter Bodelier
Hi @Deepika61,
There are 2 OOTB ways to send email from flows:
Use notifications with Send when = Triggered
Create the email directly in the flow.
If you want to send notifications using events, you will have to create a custom action, with which you can fire events using gs.eventQueue()
Help others to find a correct solution by marking the appropriate response as accepted solution and helpful.
