Issue with Translating Reference Field Values
Ramya1206
I've been trying to translate the values of a reference field, but it doesn't seem to be working as expected.
The reference field values display the user's name and position — the position value needs to be translated. This field refers to the Position field in the HR Profile table. I attempted to create translations using the Translated Text table, but the values do not change when I switch the user's language.
Could you please advise if translating reference field values is supported in this scenario? If so, what would be the correct approach to make it work?
Thank you in advance for your help.
Best regards,
Ramya
Ankur Bawiskar
@Ramya1206
the position information is stored in table "sn_hr_core_position" and comes from position field which is of type "Transated text".
So you need to create records into "sys_translated_text" table for those many records
If 100 position then 100 records into that table to store the translated value in that language
I created 1 record into "sys_translated_text" and it worked fine
Note: Ensure you clear instance cache using cache.do and then logout and login again to check
