03-28-2022 03:15 AM
Hi ,
I want the below encoded query to be added in record lookup for my flow designer.
What is the syntax for adding encodedquery in lookup record -
Case and Knowledge Management
03-28-2022 05:01 AM
I am updating it
return
"active=true^due_date<javascript:gs.beginningOfToday()^assigned_toISNOTEMPTY^parent.closed_by.managerSAMEASassigned_to"
Please mark my response as correct
03-28-2022 04:18 AM
03-28-2022 04:33 AM
Hi Ankur ,
when i add this and run the test , it shows empty value in conditions in runtime value , means it is not taking the query to look for records
What can u do for this.
Gaurav
03-28-2022 04:02 AM
HI,
You can achieve without script..
try something like below...
03-28-2022 04:13 AM
03-28-2022 04:15 AM
Okay, that's fine...
even though my solution works...give a try..
just for example.. I have used.. Trigger->record..some thing like this..
u can modify as per your requirement.
