Syntax for flow designer record lookup script
Hi ,
I want the below encoded query to be added in record lookup for my flow designer.
What is the syntax for adding encodedquery in lookup record -
I am updating it
return
"active=true^due_date<javascript:gs.beginningOfToday()^assigned_toISNOTEMPTY^parent.closed_by.managerSAMEASassigned_to"
Please mark my response as correct
15 REPLIES 15
Hi Raghu ,
not working like this.
Can we write script for lookup records , if yes , what should be the syntax.
Gaurav Tyagi
@gaurav tygai
I already shared above
sharing again here
Hi Ankur ,the above script worked but after adding return to it it should be -
return "query" ;
Marking your answer as correct.
Gaurav Tyagi
I am updating it
return
Hi @Gaurav Tyagi
Create glide record like below code... and change your encoded query according to urs and try it.
var gr = new GlideRecord('sc_task');
gr.addEnocdedQuery('active=true^short_descriptionSTARTSWITHtest');
while(gr.next())
return gr;
I hope it definetly helps you, please mark my response as correct and helpful.
