Ui actions are not visible in Hr agent workspace for HR case
puja kumari
There are few ui actions which i can't see them on HR workspace but can see on form .  This is happening in vancouver.
2 ACCEPTED SOLUTIONS
michaelj_sherid
@puja kumari Did you have the "format for configurable workspace" selected on those UI Actions? I am assuming you are not working in the configurable workspace since you mentioned the scope and it is not the configurable workspace scope (Agent Workspace for HR Case Management) but if you can verify, that will help. If you are not using the configurable workspace, I recommend you start to plan to make the move since the configurable workspace is where we are investing in the road map.
Mike
michaelj_sherid
@puja kumari  please mark this as an accepted answer so others in the same situation will have it as well.
Happy Holidays to you.
Mike
michaelj_sherid
Mike
